How to get rid of obsolete .dlr
  • How to get rid of obsolete .dlr
    Hy there,
    we just got a MAX-scene from anoffice, with the VRay-RT .dlr inside. We don´t have the RT-Plugin. If we want to render the scene in the network, the scene doesn´t render because of the missing .dlr.
    Does anybody know how to get rid of this .dlr?
    Help is pretty much appreciated, cause we need to start rendering in 2 days!!!
    Greetings, d.
    www.lightshape.net
    Good question...
    (Got the same thing here from some (older) stations with I did not mind installing RT on.)
    Alain Blanchette
    www.pixistudio.com
      In the renderpanel choose a different activeShade renderer (Scanliner)
      Regards,
      Thorsten
        All right,
        this works. The problem is, that if you don´t have the RT-Plugin, you can´t switch it off. It shows Scanline as active Shade renderer anyway. So the guy who created the scene has to switch RT off and save it. Than it´s possible to open and render it with a system where no RT is installed...
        if anybody has a better solution...?!?
        www.lightshape.net
          It's probably showing as scanline because it can't show anything else. What if you set it via Maxscript?
            Unfortunately, I don´t know how to switch the active shade renderer via MAX-script...
            But it can´t be, that there is no solution!?! Any other ideas?
            greetings and thanks for the answers!!!
            d.
            www.lightshape.net
              I thought there was a blur script for removing missing plugins, but its only for missing modifiers.
              I am pretty sure there is a script floating around somewhere for this
              Chris Jackson
              Shiftmedia
              www.shiftmedia.sydney
                Run this in the listener to set the active shade to scanliner. SHOULD work also wihout RT, but havent tried. So no guarantuees.
                Code:
                renderers.activeShade = Default_Scanline_Renderer()
                Regards,
                Thorsten
                  Code:
                  Regards,
                  Thorsten
                  Confirmed fix
                    Süpercool, Thanks Dude, this works!
                    For some reason I figured out that on a different computer it says "missing renderer" at the active shade box. if it´s like this, you can just switch to scanline and it´s working. I couldn´t figure out when which state is appearing...
                    thanks for the answers...
                    d.
                    www.lightshape.net
