error: UNHANDLED EXCEPTION: Irradiance map thread
  • error: UNHANDLED EXCEPTION: Irradiance map thread
    I have a scene that keeps crashing with this error:
    Last marker is at .\src\vray.cpp, line 2714: GlobalIllumLightDesc::Illuminate()
    It is a scene of vines/leaves overtaking the inside of a truck.. There are about 3.6M faces.. No crashes when I render single frames, but start rendering an animation and it crashes each frame..
    help!
    -Matthew
    Which 3ds Max version are you using? 32- or 64-bit?
      Max 2009 64bit..
      I can email you a scene if you like..
      -Matthew
        Yes, a scene will be helpful - you can send it to vray@chaosgroup.com
          Did you get the scene I emailed?
          Any ideas?
          I hope to get this solved, I need to render these scenes out!
          Thanks,
          -Matthew
            I have a very simple scene doing this, it crashes with unhandled exception after every frame on the IR pre pass and also on the final render after every frame
            they key being after the frame is done, and outputted the data just fine. So the render is progressing along but backburner is restarting each slave each frame adding 30 seconds down time i suppose.
            This scene is very simple, 10 objects moving about, might be very very easy for you to track down the problem. The only thing i can think of that is any different to my normal scenes is that i have two objects not visible to camera.
            WerT
            www.dvstudios.com.au
