Material with disabled maps eating memory
  • Material with disabled maps eating memory
    I noticed a scene was going crazy with memory usage and couldn't work out why, as all my maps being used were reasonable resolution.
    I eventually tracked down the culprit to a rogue VrayCompText map with HDRI map as a sub-map which had been copied through a number of my materials, but with the checkbox unticked (so theoretically not being loaded/used)...
    Is there a way for vray to ignore maps that are not switched-on to mimimize memory wastage? or is this, as I expect, an inefficiency within 3dsmax ?
    p.
    Many Thanks
    Patrick
    might be a memory problem.
    try deleting the proxies from the scene and see if the error still occurs.
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Yep I fixed the problem already, removing those maps that weren't being used fixed the problem. I just thought I should raise the issue that memory was being wasted on maps that weren't activated.
      Many Thanks
      Patrick
