pls help me: DOF enabled VrayCamera render darker
  • pls help me: DOF enabled VrayCamera render darker
    Hello,
    I have this problem that I resumed in the title.
    Below I attach 2 images, with DOF-enabled, and DOF-disabled from VrayCamera.
    Both images have same light and cemra settings except enabiling DOF.
    Is this a bug?
    Or is it supposed to be like this? If so, can anyone explain me the reason?
    Thanks in advance.
    for my blog and tutorials:
    www.alfasmyrna.com
    turn off vignette in your camera
      Thank you very much for your reply.
      I tried this and it works
      But why does vignette has this darkeninig effect on overall render frame when DOF is enabled ? Isn't vignette supposed to be darkenining of corners?
      Thanks again.
      www.alfasmyrna.com
        Isn't vignette supposed to be darkening of corners?
        yes this is correct vignetting is a darkening of the corners but it is affected (like a real camera) by aperture
        So you are reducing your f-stop no. to get stronger DOF and then balancing your ISO and shutter speed to keep the same exposure the same
        When you reduce your f-stop you are by default increasing your vignette
          Thanks you very much.
          www.alfasmyrna.com
