Comping difference between RAW VRay Passes and Straight?
  • Comping difference between RAW VRay Passes and Straight?
    Hi all
    What is the difference between the RAW element passes in Vray and the normal passes? I'm getting no success comping the RAW passes in photoshop but comping the normal passes works fine.
    I'm using:
    VrayDiffuseFilter
    Then according to Chris Nichols comping tut you should use the RAW passes:
    VrayRawLighting
    VrayRawGlobalIllumination
    VrayRawReflection
    I multiply and add as expected and the result is messed up.
    BUT
    When I use Shimakaze's tools his tools doesn't support RAW passes except for RawLighting.
    So I use the normal ones except for the RAWLighting and it works fine in photoshop.
    How can I use the RAW passes as per Chris Nichols tut in Photoshop?
    (I'm using Vray 1.5 SP3, LWF with dont affect colors(adaptation only)ticket)
    Kind Regards,
    Morne
    nobody knows?
    Kind Regards,
    Morne
      For the raw passes you'll need to also make the filter for each element too - multiply the raw by the filter so it gets darkened down, then add the result over the rest of your comp. Again you might get varying results over how different it is from the original but the raw passes are more flexible.
