Max9 sp2 , Vray 1.5sp3, winXp 32bit Sp3
In the past days I was in trouble because slaves don't start to render.
The scene rendered by DR was 117Mb.
It's a heavy scene and in initially I thought about RAM limit.
After some tests I've found that slaves don't load the scene and vraylog give me some "timeout error" from the slaves.
So I tried to reduce file size to find the limit and after some tests I've found that if file scene is less than 100Mb the slaves start to render.
It's not a LAN limit because we've tested the file transfer outside 3dsmax and vray rendering process and I can move heavy files without problem or error.
I don't know if DR in vray has a limit...and I'm not sure if it is a bug...
What could it be??
Thanks in advance
What could it be??
Thanks in advance
