VRay Light Properties not working
  • VRay Light Properties not working
    I have a rather large scene and quite a few lights. I need to adjust some specific local properties per light and when I make a change in the Light settings using the VRay Light Properties the settings do not take. Specifically the Caustic multiplier.
    If I change the value to 2, hit enter, click a different light and then back on the same light I just changed the value to, it reamins at the default of 1. This is with VRay or Standard lights.
    Any clues?
    Thank you.
    Checked if there is an anim key on the value? You probably did already...
      You can change the value also from the User Properties tab of the regular Node properties dialog, try this and see if it works.
        Thanks Vlado.
        By this I assume you mean the Object Properties/User Defined tab.
        I did this and checked back in the Light settings/VRay light properties and it seems to work.
        I will render and see.
        It does appear that this can only be done one at at time versus a group select and change as you can in the VRay light properties.
        Regards.
