Vray shadows on FumeFX Grid
  • Vray shadows on FumeFX Grid
    Hi!
    I get a bug! Vray Shadows did not cast object shadows on a FumeFX Grid.
    FumeFX grid can cast self Shadow and shadow on the ground, but I can't get the shadow from an object on the grid...
    I will adress the bug to AfterWorks but maybe you will discover if something is wrong from your side...
    Best regards...
    VRay Rock!!!
    Here is an example..
      I don't think this will work with the VRayShadows; you can try Shadow Map though, it should work.
        I get shadow on my FumeFX grid only with native 3DSMax AREA Shadow and ShadowMap...
        I don't like the idea of duplicating light in my scene... Switching ON and OFF light can create manipulation error and a wasting time...
        I can understand you don't focusing on plugin compatibility, but it will be great if you make it works...
        Best Regards...
          Is there any plan to support ABshadowmap in vray? Could it render faster if ABshadowmap was supported?
          __________________________________________
          www.strob.net
          Explosion & smoke I did with PhoenixFD
          Little Antman
          See Iron Baby and other of my models on Turbosquid!
          Some RnD involving PhoenixFD
