Error message
  • Error message
    I rendered this file on Fri and it was fine. Today I press render and it crashes right as lightcache calc starts. Attached is the error message (this seems to happen a lot I render one day and its fine - come back to the file the next day and its no good.)
    Latest vray sp4, max 2010 sp1.
    Now I merged this into a new scene and it seems ok but I swear this happens very consistently.
    Do you have region rendering selected in the V-Ray frame buffer?
      Yes apparently I do is that a no-no?
        And re-rendered unchecking that makes it render fine.
          It may happen if you had a larger resolution originally but then reduced it so the region is outside the image.
            And that is what happened.
            Thanks Vlado!
