Vraylight inside bulb model creates white splotches.
  • Vraylight inside bulb model creates white splotches.
    Hello,
    When I place the lights inside the bulb, I have splotches.
    - All scene is standard materials.
    _ Vraylights (sphere)
    Affect Diffuse
    Affect Specular
    (Dont) Affect Reflections
    Invisible
    Units : Luminous Power lm
    - Subpixel Mapping (Tried on and off and no help)
    - Clamp Output Enabled
    - Reflective GI is OFF
    - Checked geometry with AO. And all seems fine.
    - For the bulb model: removed/kept inside polygons and nothing changed.
    There are some other lights in the scene (VrayIES and other VraySphere lights) and they all render perfectly except the lights on chandelier.
    Here I enclose a cropped render
    - when lights are inside bulb
    - when lights are outside bulb
    - when chandelier is turned off
    Hope to find a solution.
    Best Wishes for Everyone and Nice Weekend.
    for my blog and tutorials:
    www.alfasmyrna.com
    would excluding the bulbs from the vraylights help?
    Nat Saiger
    Portfolio
      What is the material on the bulbs?
        It is a Vraymaterial:
        Diffuse: white
        Reflect: white (fresnel: on)
        Glossy: 0.99
        IOR: 1.8
        Refract: RGB 81 (grey)
        Glossy: 0.8
        IOR: 1.8
        fog color: white
        fog multiplier: 1
        no translucency.
        www.alfasmyrna.com
          I enclose a screenshot of the material settings.
          When I turn off bulbs , all renders fine.
          I didn't try excluıding because I would like to have shadows of bulbs.
          www.alfasmyrna.com
            Any idea why?
            www.alfasmyrna.com
              Yes, the splotches you get for the same reason that you get them if you use small objects with self-illuminated materials. Since the light is hidden inside the bulb, V-Ray has to find it by trial and error which generates a lot of noise.
              One way to work around this would be to make the bulbs not cast shadows and invisible to GI.
                Thank you very much. I will follow your advice and will post the results.
                Best Wishes
                www.alfasmyrna.com
                  Thanks again Vlado, problem is solved with your advice.
                  www.alfasmyrna.com
