flythough noise
  • flythough noise
    hi,
    im doing a flythrough at the moment and due to time constraints im using fairly low settings.
    all my bumpy materials (like lime render, pavers etc) have noise that seems to follow the camera.
    i could put up with the noise if it didnt follow the camera. is there anything i can change to fix this?
    im using lc in flythrough mode, and ir map in medium animation mode.
    lc is set to world units.
    thanks,
    Nat.
    Nat Saiger
    Portfolio
    are you using a vraysun?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      no, just an ldr in a domelight (very low intensity because its a night scene) and a bunch of vraylights.
      the noise is coming from bumpy materials that are directly lit by the vraylights.
      Nat Saiger
      Portfolio
        Thats just how the noise works - you need higher settings.
        You can turn this off and make a new noise pattern every frame but it looks kind of messy.
        If you uncheck time independant in the dmc sampler settings it does this.
          ah ok, time to up my settings.
          thanks for the reply.
          nat.
          Nat Saiger
          Portfolio
