I just started using DR and rendered a file that uses VrayToon. The remote slave does not seem to render the effect, only the local machine. Is there a trick to setting this up correctly, or is it a bug?
Thanks for the reply. I have an update, as I've discovered more about the problem working today. I noticed that the buckets rendered by the host are the ones not rendering the outline, so it may not be a DR issue after all.
What I'm finding is that the include/exclude list seems to be causing the issue. If I populate the list with a new application of the VrayToon effect it seems to work fine, then after a couple of renders and some additions to the exclude list, it will stop rendering the outline on an object that is not in the exclude list. Just the buckets rendered by the host though. If I delete the effect and reapply, creating a new exclude list, the cycle continues.
I'm using default settings for the VrayToon effect other than changing the pixel width to 1.0 and then alternating to a 3.0 width when rendering to a larger resolution. This could be part of the issue perhaps. Objects that I'm adding to the exclude list have displacement so the outline struggles to find the edges. It's weird though since the errant objects are pretty basic shapes and never added to the exclude list.
I'll try to clean up a scene to send shortly. Thanks again.
Yep, I can reproduce the issue and we are looking into it. It seems it will only happen if you hide/unhide objects between renders, but should be fine if you reload the scene.
