Can't change VRay client license settings
  • Can't change VRay client license settings
    Hello,
    I need to chance the VRay client license settings on my laptop. But whenever I start the "Change V-Ray client license settings" application, it gets started and closed again within a millisecond (popping up a message box: "Settings updated successfully") .
    I have no chance to change anything.
    A reinstallation of VRay 1.5 SP4 didn't change anything.
    I am using Vista X64 and max2010 Design.
    Vista Problem
    It is actually a Vista weirdness. Right-click 'change license settings' and select 'Run as Administrator' and then you should be able to tweak your settings.
      Make sure you are logged on as Administrator too.
        Thank you for this hint. I will have a look at this later. The machine is rendering now - although I didn't change anything.
