limited connection xp64
  • limited connection xp64
    hello, I'm trying to make my dr work with 11 computers, I realize about the 10 connection limit in xp64, so i'm trying to patch it (using "universal tcpip patch"), when i increase the number of connection allowed on a computer this computer slave start the render and just after he said render completed so i never see a cluster of this computer, when i restore the tcip.sys, it's working but the connection limit is back. Why???
    [2009/Nov/26|21:33:19] Server 192.168.1.3: Scene loaded; starting render.
    [2009/Nov/26|21:33:22] Threads completed
    [2009/Nov/26|21:33:22] Merging light cache passes.
    [2009/Nov/26|21:33:23] Light cache contains 26676 samples.
    [2009/Nov/26|21:33:23] Light cache samples collected; compiling lookup tree.
    [2009/Nov/26|21:33:23] Prefiltering light cache.
    [2009/Nov/26|21:33:23] 1 interpolation maps registered
    [2009/Nov/26|21:33:23] Rendering interpolation maps with minRate=-3 and maxRate=0
    [2009/Nov/26|21:33:23] Setting up 8 thread(s)
    [2009/Nov/26|21:33:46] Server 192.168.1.3: Render completed.
    [2009/Nov/26|21:33:46] warning: Render host rsi3 (192.168.1.3) is not responding
    [2009/Nov/26|21:34:13] Render host 192.168.1.3 added
    [2009/Nov/26|21:34:13] Scene transferred to rsi3
    [2009/Nov/26|21:34:15] Server 192.168.1.3: Scene loaded; starting render.
    [2009/Nov/26|21:34:49] Server 192.168.1.3: Render completed.
    [2009/Nov/26|21:34:49] warning: Render host rsi3 (192.168.1.3) is not responding
    [2009/Nov/26|21:35:16] Render host 192.168.1.3 added
    [2009/Nov/26|21:35:21] Scene transferred to rsi3
    [2009/Nov/26|21:35:25] Server 192.168.1.3: Scene loaded; starting render.
    [2009/Nov/26|21:35:44] Cancelled.
    [2009/Nov/26|21:35:44] Threads completed
    [2009/Nov/26|21:35:44] Calling endPass() on irradiance maps
    [2009/Nov/26|21:35:44] Calling prePassDone() on irradiance maps
    [2009/Nov/26|21:35:47] Image prepass completed.
    [2009/Nov/26|21:35:47] Rendering image.
    [2009/Nov/26|21:35:47] Setting up 8 thread(s)
    [2009/Nov/26|21:35:47] Threads completed
    [2009/Nov/26|21:35:47] Calling endFrame().
    [2009/Nov/26|21:35:47] Entering endFrame().
    [2009/Nov/26|21:35:47] Broadcasting NOTIFY_POST_RENDERFRAME.
    [2009/Nov/26|21:35:47] Applying render effects.
    [2009/Nov/26|21:35:47] Waiting for DR to finish
    [2009/Nov/26|21:35:47] Number of raycasts: 48518806
    [2009/Nov/26|21:35:47] Clearing global light manager.
    [2009/Nov/26|21:35:47] Clearing direct light manager.
    [2009/Nov/26|21:35:47] Clearing ray server.
    [2009/Nov/26|21:35:47] Clearing geometry.
    [2009/Nov/26|21:35:47] Calling frameEnd() on render instances.
    [2009/Nov/26|21:35:47] Calling frameEnd() on render objects.
    [2009/Nov/26|21:35:47] Calling frameEnd() on render materials.
    [2009/Nov/26|21:35:47] Clearing camera image sampler.
    [2009/Nov/26|21:35:47] Clearing camera sampler.
    [2009/Nov/26|21:35:47] Clearing DMC sampler.
    [2009/Nov/26|21:35:47] Clearing path sampler.
    [2009/Nov/26|21:35:47] Clearing color mapper.
    [2009/Nov/26|21:35:47] Region rendering: 150,7 s
    [2009/Nov/26|21:35:47] endFrame() done
    [2009/Nov/26|21:35:47] Updating irradiance map info.
    [2009/Nov/26|21:35:47] RenderAtTime() done.
    [2009/Nov/26|21:35:47] Stopping frame timer.
    [2009/Nov/26|21:35:47] Total frame time: 151,8 s
    [2009/Nov/26|21:35:47] Render() done.
    [2009/Nov/26|21:35:47] Entering Close()
    [2009/Nov/26|21:35:47] Calling endSequence().
    [2009/Nov/26|21:35:47] Entering endSequence().
    [2009/Nov/26|21:35:47] Calling renderEnd().
    [2009/Nov/26|21:35:47] Calling renderEnd() on render materials.
    [2009/Nov/26|21:35:47] Sending RenderEnd().
    [2009/Nov/26|21:35:47] Sending RenderEnd() to atmospheric effects.
    [2009/Nov/26|21:35:47] Sending RenderEnd() to render effects.
    [2009/Nov/26|21:35:47] Sending RenderEnd() to the tone operator.
    [2009/Nov/26|21:35:47] Sending RenderEnd() to environment maps.
    [2009/Nov/26|21:35:47] Sending RenderEnd() to override mtl.
    [2009/Nov/26|21:35:47] Unloading bitmaps.
    [2009/Nov/26|21:35:47] Freeing render instances and lights.
    [2009/Nov/26|21:35:47] Broadcasting NOTIFY_POST_RENDER.
    [2009/Nov/26|21:35:48] Closing DR
    [2009/Nov/26|21:35:48] endSequence() finished.
    [2009/Nov/26|21:35:48] Sequence timer stopped.
    [2009/Nov/26|21:35:48] Total sequence time: 152,4 s
    [2009/Nov/26|21:35:48] Enabling scene redraw and autobackup.
    [2009/Nov/26|21:35:48] Close() done.
    [2009/Nov/26|21:35:48] warning: 0 error(s), 2 warning(s)
    [2009/Nov/26|21:35:48] ================================
    [2009/Nov/26|21:36:19] Saving to file.
    [2009/Nov/26|21:36:19] Saving distributed renderer.
    [2009/Nov/26|21:36:19] Saving filter parameters.
    [2009/Nov/26|21:36:21] Saving done.
    If you check the V-Ray log file on the render slave, does it say anything useful?
      hello vlado
      Thank you for your answer, after the manipulation yesterday, i did not back up the original tcpip file, so I had to restore all originals system files from the windows dvd....
      After reading your answer, i check the vray log today but it was empty, so I've just give it a new try with the same patcher, open 500 connections...
      It's working now... i will patch all computers tomorrow to see if all computer work together well! thanks for your help, maybe I will try to put more network cards on the computer which store the maps and stuff.
      Thanks
