Gi receive 0.8 Bug on some slave
  • Gi receive 0.8 Bug on some slave
    hi, I am really becoming crazy.
    I render an animation, on 6 PC, through Back burner
    3dsmax 2008, same service pack an update on every machine
    XP64 SP2 every machine update
    Main PC Intel Q6600 Render fine Even on object set to GI receive 0.8
    PC Intel I7 920 render Fine Even on object set to GI receive 0.8
    4 others slave Q9450 Render WRONG , Only on Objects With "GI RECEIVE SET TO 0.8" . It render DARKER, not just a little it seems on that particular objet GI is missing. Why ? every other part of the image is perfect, GI perfect, Objet Perfect, Vmesh OK.
    LC and IRR are pre calc, save on Map drive.
    And I repeat, every other objets in scene are good, GI is good on those machines too.
    Any answers. Please really need help, cant render that animation on only 2 machines.
    thanks a lot.
    This usually happens when some of the slave machines have coma (,) as the symbol for decimal values.
    Check windows regional settings on these machines and make sure you have period (.) as the decimal symbol (Control Panel\Regional Settings\Customize\Decimal Symbol).
      I ll try it right now , hope this is the solution.
      Thank anyway for your answer
        Yes It defenitky Works !!
        I changed "coma" by a "dot", and everything back right.
