vray camera
  • vray camera
    hi,
    when using a vray camera with vray sky in environment and effects metals will have reflection of the sky in the objects.
    but instead if i use a hdri map in the same slot the is no reflection of the map in the metal objects.
    even if i put the map in the vray environment i dont get any reflection.
    kindly advice.
    It might be that your environment map is too dark; try increasing its brightness to see if it shows up.
      hi i tries but i dont get any ref if i use a differnt map besides vray sky
        Savio, have you tried putting your HDR image in the V-Ray Environment Reflection/Refraction Override slot?
        -Alan
