PArray Not rendering - Is it Vray ?
  • PArray Not rendering - Is it Vray ?
    Hi
    I use PArray for hedge creation and for some odd reason - it does not render.
    The particles are seen in the viewport so my first guess that the life-length of it has to do is discarded.
    I also use ForrestPAck object near by - (not sure if it has to do with it)
    Anybody had this issue ?
    NIR
    3ds Max 2016/2021 (Vray 5.005), Windows 10 64bit , AMD 32/64 Cores, 128 gigs RAM , 2X GTX1070 8GB RAM
    Do they render with the scanline renderer?
      I tested a small file with only a PArray and it rendered inside Vray.
      But the project file is not rendering.
      Could it be a matter of size (quantity of particles?)
      I doubt that it has to do with Vray - unless there is a memory clash when big amount of Particles is involved (or the ForrestPack objects)
      I will export the problematic PArray obj to an external file and test with VRay.
      Nir
        Are you DR?
        My Parray objects never render if I use DR (host machine renders OK but slaves don't?). Never found the solution...
        Zoran
          yes - DR.
          Vlado - is it Vray then ?
          Nir
            I'm not sure; do you have a scene that I can test?
