Probably dumb: max lights won't render
  • Probably dumb: max lights won't render
    I'm sure it's a dumb thing - but I have a stock scene I just bought and I'm converting it over to Vray. Problem is that the Max lights (spots and omni's) won't render in Vray, but they render fine in Vray RT
    Is there an obvious switch/setting somewhere for the production render that I'm missing ? Vray Light Material renders fine in both, just the max lights that won't work.
    Thanks in advance
    b
    EDIT: Vray lights aren't rendering either. Never had this problem before - I'm stumped.
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    Maybe there is something in the Global switches under lighting that is turned off.
      The only thing I could find was default lights off/on, which is off, but I always have that off. Tried merging everything into a new scene and still no joy. Weird.
      Brett Simms
        do you have a physical camera with exposure on or exposure of some sort?
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          You might try mreging the whole scene into a new, reset file therefore resetting all renderer parameters.
          -Alan
            Yes, but it's not an exposure issue because I can see the Vraylight Materials normally, and cranking up the exposure does not reveal the Max lights. Exposure also looks fine in RT.
            Appreciate the help guys.
            Brett Simms
              -Alan
              Yep, did that already and same deal.
              b
              Brett Simms
                This is driving me crazy. I attached a simplified scene. It renders the light in VrayRT, but not in VRay. It's gotta being something dumb I am missing, but damned if I can figure it out. Anyone have a chance to look at the file?
                b
                Brett Simms
                  Just opened it, I see a big blue light in RT, nothing in the VRay. Let's inspect this closer ....
                    I think I might have solved this little conundrum... In the environment and effects, the Global Lighting Tint level is at 0.0, if it is raised to the normal default 1.0, there is light!
                      You're a life-saver - this was driving me crazy! I thought that was only for ambient light, but I hadn't even noticed that. Thanks Robert!
                      b
                      Brett Simms
                        Lol ! im sure it was driving you crazy hahaha...it happens to me sometimes...u sit there bonking your head on the desk....like wtf!!!!!!!!! =) glad u got it figured out.
                        Ruben Gil
                        www.spvisionz.com
                        www.linkedin.com/in/s2vgroup
                          These are the times that "unbiased" render engines start to seem REALLY appealing. Just so few buttons to turn on/off by accident
                          b
                          Brett Simms
                            could be some vray problem. Merging into clean scene fixes it though.
                            Dmitry Vinnik
                            ShowReel:
