SP04a - vray plane is gone?
  • SP04a - vray plane is gone?
    Hi - I just installed SP04a on Max 64bit Win7 and I'm trying to render an old scene. It seems that Vray plane has been discontinued - is that so? I thought it was really useful. It also appears that VRay blend materials are gone. Has anything else been removed and why I wonder?
    The V-Ray plane is there, as well as the blend material. Do you get any error messages when starting 3ds Max? Sometimes two lines in the plugin.ini file get swapped and the extra V-Ray plugins don't load - in that case you must edit the file manually and make sure that the "Additional V-Ray plugins" folder is the last one.
      That fixed it alright - phew! Thanks!!
