Hi all,
There seems to be a problem with the default cutoff value [Reflections] in Vray material using a Falloff map.
The default value of 0.01 seems to be way too high and produces no reflections or a sever cutoff/edge when using a Falloff map.[SEE images below]
Have had this problem a few times now & can consistently reproduce the same issue.
Is there some way to change this default value in Vray material??? So that I don't have change all mats manually or with scripts.
Thanks
Thanks
