I have a huge problem with an animation i am doing right now. So far i calculated the LC and now i wanted to calculate the irradiance map, and here is the problem, my render slaves are only rendering the first frame, after that my worksation is prepassing the frames alone, they slaves just dont join the fun.
Another strange thing is that once my workstation is done with a frame i will get the message in the vray log that the slaves are starting, but only after the whole frame is done allready and they never start to do anything except for the first frame. Sometimes one slave is starting but i only had that once. I also attached some screenshot, dont know if they help, first on is frame 0 were everything is fine, the other ones are the one were nothing happens. I am using the incremental add mode for the prepass but i also tried multiframe incremental which makes no difference.
WinXP64
3dsmax Design 2009
VRay 1.5 SP4a
EDIT: tried to switch to single frame, just to see what happens....well like before, the first frame is fine, on the second frame there is allready one slave missing, on the third frame two more slaves are missing and on the 4th frame guess what, my workstation is rendering alone.....this is drinving me crazy.
I am using the n-th frame method but i dont think it has something to do with it.
WinXP64
3dsmax Design 2009
VRay 1.5 SP4a
