Lots of proxys - problem
  • Lots of proxys - problem
    When I use more then 1 000000 proxys even as instances I got problems with 3ds max crashing after 10 minutes unloading geometry. Any chance to speed things up and stop max crashing?
    Do you have a lot of ram and have you raised the Dynamic memory limit?
      How does it crash? With a CER dialog or with the V-Ray unhandled exception message?
        To be onest I'm trying to run on my laptop with 3gb memory, the dinamic memory is set to 3000 but I think it's not in laptop problem just for a test I use vrayscatter with the same proxy object and 2000000 proxys run without max crash.
        There is no vray related error message, when max is unloading geometry after a while he just crashes, no errors dialog at all.
        Maybe plugin vrayscatter uses some kind of direct conection with vray and just send proxys to it?
          Would it be possible to get me the scene to vlado@chaosgroup.com so that I can figure out where is the crash?
