Render Presets Crashing
  • Render Presets Crashing
    I'm having a problem using Render Presets. When I try to load any Vray render preset I get a crash. I saw another user had this problem on the forums, but it was due to Solid Rocks. I don't have that script. Scanline presets load fine, but Vray presets instantly crash out of max.
    One other user, Grant Adam of RPManager fame confirmed the same behavior on his computer.
    I'm using max 2010 64-bit on Win 7. I should probably mention I also have Vray RT installed, but I doubt it's related.
    Anyone else seeing this?
    I've got same problem when loading presset two or three times in the same scene, but when I switch to vray presset manager everything works fine.
      Can you send me one of these crashing presets files to vlado@chaosgroup.com?
        I have the same problem
        3ds max design 2012, vray 2.10.01
        few months earlier everything worked fine
        It even appears when I create new preset from scratch
        I've attached archive with presets cousing problems (one with vray settings only, and one wit all settings)
        Vray.zip
        gomo.pl
