License Problem 1002
  • License Problem 1002
    We recently got two workstations running Win 7 64. (Max2008/vray sp3)
    We have 3 dongles that are used on various workstations localy where needed.
    I installed Vray/Max 32/64bit on these 2 new machines and I choose local license server.
    The vrlservice.exe is started on both and both have a dongle attached. Now whenever one workstation is rendering
    the other one won´t render with error code 1002. Like one workstation would use the license of the other one, it seems.
    We also occassionaly experience this problem with a Win 7 machine and one of the old XP workstations.
    After a max restart the problem is solved for another hour. We never had this problem until we
    used these new workstations.
    The error code (1002) means that all the licenses are already taken out by other machines.
      Those errors occur now more and more often. The license can´t/shouldn´t be taken by another machine. All dongles are attached directly to the specific workstations where
      needed. All were installed with local license server. But it seems that the license is beeing
      taken by network/distributed rendering. As these errors only occur when someone is
      rendering on the network. As far as I understand network rendering shouldn´t block
      a license while rendering.
      Also I´m getting more and more often "error 10061" when rendering with backburner
      on the slave machines.
      We really need a solution ASAP as we are wasting a lot of time a the moment just with license problems.
