Hi there,
I have furry characters in my scene. I need to comp the fur, so I wish to render it alone. So, I need to :
- set the fur non visible to camera (if I set the emitter "non visible to camera" , it does not change the fur appearance, only the emitter)
- set the fur non renderable (the only way I found to prevent the fur from rendering is to disable the modifier, because changing the renderable properties of the emitter doesn't affect the fur neither)
It would be great if the hair and fur could absord its emitter render properties...
But it would even more greater if the fur could have its own render properties (sometime, you need the emitter to be hidden and not the fur...), otherwise I have to reference the emitter object, it's a little bit heavy.
Thanks!
Thanks!
