Problem removing VRay Mesh Lights
  • Problem removing VRay Mesh Lights
    I've been trying to use some vray mesh lights, but now I want to remove them. I can't seem to delete them though!
    Don't know if it is relevant, but the geometry is file linked from AutoCad.
    How on earth do I get rid of these things???? I can even change them to plane lights, but I still can't delete them!
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Hm, can you send me the file (even with just the lights)?
      Could you give me your email address again please? I tried to 'private message' you but was informed your mailbox quota was full!
      <found it!>
      Kind Regards,
      Richard Birket
        It is vlado@chaosgroup.com, should have included it in the post - sorry about that.
          So to remove the light, create a sphere, and set that sphere as the source mesh for the VRayLight. Then you will be able to delete it. Not sure why the original issue happend, but it seems to be a glitch in 3ds Max.
            I had the same issue with linked dwg, I comfirm above solution.
