VRAY RT Not Rendering Bitmaps?
  • VRAY RT Not Rendering Bitmaps?
    Any ideas why this is happening?
    Works fine with procedural textures...i.e checker, just not displaying bitmaps using jpegs as the maps.
    Do you see any warnings in the V-Ray RT render server window? Are the maps stored locally on the disk, or on a network location?
      No errors, maps stored on server, just moved them to local drive and it works now......can you not keep them on network drives then?
        You should be able to keep them on a network drive; the RT render server window should print out a warning if it fails to load a bitmap, along with an error code.
          I see what I have done wrong I never registered the VRAY RT render server as a service, now I have it has loaded in the bitmaps, thanks for you help.
          Mark
