I'm trying to create looping animations from Onyx treestorm trees by using proxies and I am constantly getting errors.
In Treestorm, there doesn't seem to be an easy way to set a loop for a tree animated by wind, so I've used morph-o-matic to blend the end frame.
However, when I convert it to a VRay Proxy, I get a maxscript error - this also happens when I just use a basic Onyx Tree, so it doesn't appear to be down to the morphing plugin.
The animations are reasonably long (about 360 frames), but it seems more prone to happen if it's a longer animation or a higher poly count tree.
Unfortunately I didn't make a not of the exact maxscript error, but has anyone come across anything similar, or have a suggestion?
Thanks,
Steve
Thanks,
Steve
