Frame Buffer and Z-depth
  • Frame Buffer and Z-depth
    Hello,
    How can I make z-deaph pass when using Vray Frame buffer?
    Dont know why, but all I am getting is blank black image at the end. I am using 1m-15m in settings.
    Check your scene scale as max has two scale settings
    One for actual world scale & one for viewing scale [You may be viewing max in meters but the actual world scale may be millimeters!! this will cause the problem you are having]
    You need to make sure the world scale is set to meters if you are setting z-depth to meters
    Other than that there is not much that can go wrong with Z-depth
      ahh wrong forum
