There seems to be a bug with the Vray Environment Fog and Z-depth passes.
As you can see by the attached image, the Fog seems to be affecting the Z-Dpth pass when 'ENABLE FILTERING is turned on.
It works fine if Filtering is turned off.....it just does it when filtering is turned on [which I need for opacity mapped leaves.
I have been able to reproduce it consistantly since I discovered it last week, so I guess it's not really a bug just the way it currently works....can we have this changed/fixed please vlado??
Max 2008 64bit
Vray 1.5 sp4
Thanks
Max 2008 64bit
Vray 1.5 sp4
Thanks
