I have always had the vray spawner open automatically at the start of the computer. After just installing windows 7 I noticed the possibility of registering it as a service. Though, when I do this the buckets render without the materials. However, if I launch vray spawner then all renders fine.....though on windows 7 I cannot get the spawner to open automatically......some authorization problem I imagine?? Any else with this problem?
vray spawner as a service vs launching it
Same here. We have XP x64 on all the slaves still, but when the spawners are registered as services the slave-buckets don't pickup the textures. I have no idea why this is. If there is a way to get around that somehow I'd really greatly appreciate!
Right now, it is quite time consuming to restart or shutdown all slave machines - login via vnc, end spawner task, shutdown. If the service could be used instead, one could just press the power button to shutdown. The other way around if the spawner task is still running it won't shut down but freeze in the logoff process.
The main advantage with service is that you can run it from a computer without the user knowing you are using his/her computer. You can also run the service as a different user, wich can be usefull for drives privileges.
For the missing maps, if you are working UNC paths, there should not be any problems.Alain Blanchette
www.pixistudio.com
usually this is a permission issue. The service by default runs as the "SYSTEM" user if i recall right. So in the services properties you need to set it to run as the user that is allowed
to access the textures (the gui user you use when launching the spawner manually i'd say).
Another advantage is automatic restarting upon crashes and alike for services.
Regards,
Thorsten
The only way I ever got mine to work was have all my worksations named the same, using the same password. When I run the service I run it as that user. I just installed WIN 7 on my main workstation and the spawner didn't work until I renamed the workstation and logged in locally. Once I rename the new WIN 7 workstation as all the other ones, logging in locally, I am back in buisness.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Thanks for the quick replies!
The drive of the file server is mapped on all workstations and slaves with the same letter. So while using the spawner as a task everything is fine.
Thanks again!
I'll give it a shot as soon as I find some time to test it.
Still I wonder about one thing: the slaves are automaticly logging in to the corresponding account (via TweakUI). If I'm right the drives will be mapped after the log-in. But wouldn't the spawner service start before log-in? And could the missing drives at the service initiation lead to missing textures as well?
Best,
Fritz
