Is it possible to link cut-off values of different mat
  • Is it possible to link cut-off values of different mat
    I woul like to adjust the cut-off value for a dozen of related materials. I don't see that vlue in the material slate editor in max 2011. and I don't see it neither in the parameter wiring editor...
    Is there any way to link those values together... If I lower it for all my scene with a mascript command I saw on the forum, it may increase render time too much...
    __________________________________________
    www.strob.net
    Explosion & smoke I did with PhoenixFD
    Little Antman
    See Iron Baby and other of my models on Turbosquid!
    Some RnD involving PhoenixFD
    The parameter is not animatable; you can only wire parameters than can be animated. The other way is to do it through MaxScript.
      Ok thanks,
      As I'm not so advanced in scripting (I need to get through Bobo's course), I did some baby script like that:
      cutA=0.01
      rootScene[#SME][#rouge][#coat07____VRayMtl].Properties.reference.option_cutoff = cutA
      rootScene[#SME][#rouge][#coat02____VRayMtl].Properties.reference.option_cutoff = cutA
      rootScene[#SME][#rouge][#coat01____VRayMtl].Properties.reference.option_cutoff = cutA
      rootScene[#SME][#rouge][#coat06____VRayMtl].Properties.reference.option_cutoff = cutA
      rootScene[#SME][#rouge][#coat04____VRayMtl].Properties.reference.option_cutoff = cutA
      rootScene[#SME][#rouge][#coat05____VRayMtl].Properties.reference.option_cutoff = cutA
      It works but I would be curious to see how a pro would have instead get the array of materials and then apply the value to it...
      Is there a way to select some materials in the slate editor and then get an array of those materials.
      www.strob.net
      Little Antman
