VRay Runtime Error with 3DS Max 2011 Design (German) and VRay.
  • VRay Runtime Error with 3DS Max 2011 Design (German) and VRay.
    Hi!
    Whenever I try to reset the Material Editor of 3DS Max 2011 Design with VRay SP5 I get the error you can find in the attachment.
    Everything works fine with 3DS Max 2010 Design and SP4a.
    The complete Script-PopUp looks like this:
    Code:
    -- MacroScript File
    -- Created:       Feb 09 2005
    -- Last Modified: Feb 25 2005
    -- Medit Utilities
    -- Version: 3dsmax 8
    -- Author: Alexander Esppeschit Bicalho, Discreet
    -- Modified: Alexander Esppeschit Bicalho, Discreet
    -- MODIFY THIS AT YOUR OWN RISK
    /* History
    Feb 09 - created script
    Feb 10 - fixed problem where defaults.ini uses Hex number and ClassID is an Int
    Feb 10 - added Restore Medit Slots script
    Feb 11 - added Localization Notes
    Feb 25 - added Condense Medit
    Feb 25 - moved functions to meditfunctions.ms in StdScripts
    NOTE TO LOCALIZATION
    Only the headers should be localized
    macroScript clear_medit_slots
    enabledIn:#("MAX", "VIZ")
    	category:"Medit Tools"
    	internalCategory:"Medit Tools"
    	ButtonText:"Material-Editor-Felder zurücksetzen"
    	tooltip:"Material-Editor-Felder zurücksetzen"
    on execute do
    	defaultMtlLibFile = MeditUtilities.getDefaultLibraryFile()
    	if defaultMtlLibFile != undefined do
    		defaultMtlLib = loadTempMaterialLibrary defaultMtlLibFile
    		global _meditMaterialsBeforeReset = #()
    		for i in 1 to meditMaterials.count do
    			append _meditMaterialsBeforeReset meditMaterials[i]
    			if i <= defaultMtlLib.count then
    				meditMaterials[i] = defaultMtlLib[i]
    			else
    				meditMaterials[i] = defaultMtlLib[defaultMtlLib.count]
    macroScript restore_medit_slots
    	ButtonText:"Material-Editor-Felder wiederherstellen"
    	tooltip:"Material-Editor-Felder wiederherstellen"
    on isEnabled do (if classof _meditMaterialsBeforeReset == Array do _meditMaterialsBeforeReset.count > 0)
    on execute do
    	if _meditMaterialsBeforeReset.count == meditMaterials.count do
    			meditMaterials[i] = _meditMaterialsBeforeReset[i]
    		_meditMaterialsBeforeReset = undefined
    macroScript condense_medit_slots
    	ButtonText:"Material-Editor-Felder komprimieren"
    	tooltip:"Material-Editor-Felder komprimieren"
    on execute do
    		usedMtls = #()
    			if MeditUtilities.isMaterialInUse meditMaterials[i] == true do
    				append usedMtls meditMaterials[i]
    			if i <= usedMtls.count then
    				meditMaterials[i] = usedMtls[i]
    			else if i <= defaultMtlLib.count then
    			else
    macroScript basic_material_editor
    	ButtonText:"Kompakter Material-Editor..."
    	tooltip:"Kompakter Material-Editor..."
    on execute do
    -- close sme if needed and open Medit
    	maxOps.mtlDlgMode = 0
    	if (sme.IsOpen()) do sme.Close()
    	-- Safe to call redundantly. Will restore window if minimized.
    	matEditor.Open()
    macroScript advanced_material_editor
    	ButtonText:"Erweiterter Material-Editor..."
    	tooltip:"Erweiterter Material-Editor..."
    on execute do
    -- close Medit if needed and open sme
    	maxOps.mtlDlgMode = 1
    	if (matEditor.IsOpen()) do matEditor.Close()
    	sme.Open()
    I reinstalled VRay SP5 a few times now.
    What could be the reasen / what could be a solution?
    Greetings and thanks!
    it sounds like this issue here-
    http://www.chaosgroup.com/forums/vbu...aleditor-reset
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Oh, you are right. I did not find any related threads. Thanks.
        Yep; we are looking into this; for now, just do not use the MAX.vray preset.
          OK, thanks for your answer.
