Fog Colour
  • Fog Colour
    Hope this is an easy one, I'm working on the materials for an orange indicator light on a car project. For the life of me i can't get the fog colour on the light bulb to be Orange.
    As you can see in the attached image the colour picker is set to orange yet the rendered image is yellow. I've tried fog intensity's extremely high and low with the same "colour" result. Shifting the colour picker along either seems to snap to red or yellow no in between orange. Also exit colours on/off.
    Max 2010, Vray 1.5 SP4a
    James Hall
    Technical Director
    New Zealand
    www.jhall.nz
    try setting the diffuse colour to black, then you can make the refraction colour orange as well as the fog. might even work without fog, but I guess that's up to you.
      id set the exit color back to default. i usually put diffuse and fog as the same then crank up the fog to something like 0.2 or 0.3 all depends on the look you need
        Thanks for the responses. Upping the amount and setting diffuse to same orange did it. Still quite a bit of yellow in the fog but the orange diffuse masks it enough.
        James Hall
        Technical Director
        New Zealand
        www.jhall.nz
          did you reset the exit color?
            Yes i did try resetting the exit color to black/white/orange with little chance, orange was the best though.
            James Hall
            Technical Director
            New Zealand
            www.jhall.nz
              what about the fog multiplier?
