Displacment
  • Displacment
    I have having an issue with displacement in the latest build of V-Ray under 3D Max Design 2011.
    I have a foundation that tapers in so I extruded a line, grabbed the top corners, and pulled the top back several inches. When I apply my V-Ray Displacement the displacement seems to go up and not out.
    Am I doing something wrong?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    are you using 2d or 3d mapping?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      I am using 3D, but I guess I can try 2D and see if it is any better.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I tried 2d and it worked much better, but I can't connect the corners like I can with 3D. Here is what I am getting with 3D...
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          same geometry except I picked 2d for the displacement type
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            As far as I understand Vray displacement works off surface normals.....so it is very important that your normals are correct.
            If it's not doing what you want because of the normals then you could try using the vector displacement as this way you can control which direction the displacement goes.
            But I may add that for such simple geometry you would be better off modeling the geometry. You'll get exactly what you want with massivly less polygons & I'm sure you could have modeled it in the same amount of time that you've struggled to achieve it with displacement & not succseeded.
            Hope this helps
              Isn't there a way to display the normal direction? I looked, but I can't find anything. These model I get are usually from Revit, which are typically poorly modeled.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                there certainly is!!
                if you select the faces on an editable-mesh object you have a small checkbox to show normals.
                [it's in the first panel called selection and you can adjust the scale of the lines ]
                what you will get is a blue line showing the direction of the normal
                if your object is an editable-Poly simply put an temporary edit- mesh modifier on it to check this out as it doesn't have this option with the editable-poly
                this is an invaluable tool when it comes to working with bad models made from architects.
                all the best
                  Here is a snapshot of it
                    Holy Cow! I have looked for this forever, almost a year, thanks!
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
