backburner problem and I think IR map loading file error????
  • backburner problem and I think IR map loading file error????
    Almost every time I send an animation on backbuner at least one of the render nodes renders the scene darker like this example I am posting. Every frame of the animation done by that render node is dark. THough, it is not always the same node. In other animations it is another render node that causes the problem. I'm guess that there is some network problem and the IR map is not loading correctly?? Though, I do not know what to do about this. After each animation I have to go through frame by frame to find the dark ones and rerender. VERY ANNOYING! Anyone else seen this problem???
    We've had problems like this in the past due to regional settings, but it happened always with the same machine ...
    Just to be sure, you can identify one render node that produced a darker image and check that it has . (period) as decimal symbol in the regional settings.
    Cheers
      YEah...I have had that problem in the past.....but this time it is a BIG mystery! I wish it was just that......that was easy to solve......even though it took time to figure it out!!!
