Bug using DR as a service.
  • Bug using DR as a service.
    When Vray 1.5 sp5 DR is installed and registered as a service, it does not load any maps and just renders the diffuse.
    If it is not registered as a service and loaded manually using the Startup folder in program files then it renders fine.
    Maxscript made easy....
    davewortley.wordpress.com
    Follow me here:
    facebook.com/MaxMadeEasy
    If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
    we have it installed and registered as a service on windows 7 and it is working.
      We're on Xp64
      Follow me here:
        This is not a bug, this is most likely because you need to let the service log on with an account that has access to anyplace you might keep your assets. Set it up in the service's properties window.
        Signing out,
        Christian
