I've been trying to narrow down some persistent DR problems we have. Here is a simple file - I've removed almost everything other than a camera, daylight and a couple objects that are xref'd in. I've tried everything from renaming objects, stripping uv's, adding uv's, welding, removing materials, clearing vray properties, assigning vray properties but can't seem to make it work.
I'd like some other eyes on this to see if we can come up with a solution before assuming it's a bug... To test this you'll need to extract the 2 max files somewhere network accessible and repath the xrefscene. Open up "masterScene" and repath "sourceXref" so it's accessible on your network and try and render. You'll get black buckets that don't make any sense. I've verified this on 2 separate computers at our office but would love to find a solution.
Max 2011 - http://www.chaosgroup.com/forums/vbu...0&d=1278026151
Max 2010 - http://www.chaosgroup.com/forums/vbu...9&d=1278026151
Thanks,
Thanks,
