Scale animation do not work with Use Camera Path method?
  • Scale animation do not work with Use Camera Path method?
    hi there,
    I have a series of objects in my scene that has properties of its scale and visibility animated.
    So to elaborate on this, a box is visibility 0% scale 0% at frame 0. Over a period of 25 frames, the box scales to 100% and visibility 100%.
    With a moving camera over a hundred of these scaling boxes, I figured I'd use Animation Prepass and Animation Rendering method with "Use Camera path" option.
    But each time I calculate the Animation Prepass and switch over to Animation Rendering for the final render, vray spits out "unhandled exception etc" error message - which I figured was due to no data being saved inside the irradiance maps. (Each time I click on the load saved irradiance maps, it reads 00 Samples and 0MB)
    Am I doing something fundamentally wrong here? Can someone give me a hand with this?
    Cheers.
    regards,
    Jung
    Hello Jung,
    If you are using the "animation prepass" option you will need to calculate the GI for every frame so you wont be able to use the "use camera path" option as that calculates the whole animation range
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
