SP5 dr server fails
  • SP5 dr server fails
    I am trying to set up a DR server on a machine. It's running a 32bit version of max, and im giving the task from a 64bit rig. This used to work before.
    I get the brown line stating that the scene has loaded and has started rendering, but then the next one is also brown and says "render completed". The next one is a warning saying that the host is not responding.
    Dusan Bosnjak
    http://www.dusanbosnjak.com/
    I can't seem to run a job through backburner either though. It says its missing plugins but it doesnt state which ones.
    Can backburner work between 32bit and 64bit? I just created a simple sphere in an empty scene and tried rendering it with scanline, how come its asking for plugins?
    Dusan Bosnjak
      hey it might be RT
      Martin
      http://www.pixelbox.cz
        what does that mean?
        Dusan Bosnjak
          vray RT if youre using it
          Martin
            i am not using RT
            Dusan Bosnjak
              I kept looking at the spawner txt file, but now i took a look at vray txt and it seems to be a licence issue. The firewall on the machine is turned off, how can i check if it can obtain the licence or not if its a render slave?
              Dusan Bosnjak
                My issue was an improperly set up licence on the slave. Now i have a whole bunch of different issues. At one moment, everything worked just fine, i had 4 machines rendering one image flawlessly. They even read the proxy along with a bunch of maps.
                Then they started failing, and now one persists. After reseting the spawner, and eventually the machine, it accepts the connection, but it doesnt read any of the files. Even though it worked just an hour ago. I have my local drived mapped as S: on every machine, and i can access it fine from that particular slave.
                [2010/Aug/6|01:22:27] Entering beginFrame().
                [2010/Aug/6|01:22:27] Setting RenderGlobalContext.
                [2010/Aug/6|01:22:27] Broadcasting NOTIFY_RENDER_PREEVAL.
                [2010/Aug/6|01:22:27] Updating the tone operator.
                [2010/Aug/6|01:22:27] Preparing camera sampler.
                [2010/Aug/6|01:22:27] Calling update().
                [2010/Aug/6|01:22:27] Updating scene materials for time=0
                [2010/Aug/6|01:22:27] Loading bitmaps for "01 - Default"
                [2010/Aug/6|01:22:27] Updating "01 - Default"
                [2010/Aug/6|01:22:27] Loading bitmaps for "DefaultVRaySky"
                [2010/Aug/6|01:22:27] Updating "DefaultVRaySky"
                [2010/Aug/6|01:22:27] Loading bitmaps for "Material #25"
                [2010/Aug/6|01:22:27] Updating "Material #25"
                [2010/Aug/6|01:22:27] Loading bitmaps for "Map #5"
                [2010/Aug/6|01:22:27] Updating "Map #5"
                [2010/Aug/6|01:22:27] Loading bitmaps for "Map #3"
                [2010/Aug/6|01:22:27] Updating "Map #3"
                [2010/Aug/6|01:22:27] Loading bitmaps for "Map #2"
                [2010/Aug/6|01:22:27] Updating "Map #2"
                [2010/Aug/6|01:22:27] Loading bitmaps for "07 - Default"
                [2010/Aug/6|01:22:27] Updating "07 - Default"
                [2010/Aug/6|01:22:27] Preparing objects
                [2010/Aug/6|01:22:27] Updating object VRayProxy01, VRayProxy02, VRayProxy03, VRayProxy04, VRayProxy05, VRayProxy06, VRayProxy07
                [2010/Aug/6|01:22:27] warning: Failed to initialize proxy object "VRayProxy01, VRayProxy02, VRayProxy03, VRayProxy04, VRayProxy05, VRayProxy06, VRayProxy07" with file "S:\!!!!!!\iTrees-01-GenericTree_05.vrmesh"
                [2010/Aug/6|01:22:27] Updating object Sphere01
                [2010/Aug/6|01:22:27] Validity for node "Sphere01" is [forever], node handle is 21
                *edit*
                I even opened the scene through the network on the render slave, and it works, and renders fine.
                Dusan Bosnjak
