Changed the PowerSupply - Dongle not recognised ?
  • Changed the PowerSupply - Dongle not recognised ?
    Hello
    Yesterday I took my PC to the lab to change the PoswrSupply which broke and at home, after re-plugging the dongle - Vray just doesn't see it.
    I reinstalled both Vray and WIBU and restarted it , re edited the license key file (the one with Localhost and 30304)
    Also , I tried accessing it from the browser :
    http://localhost:30304
    NOTHING !!!
    HELP !!!!
    NIR
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    have you tried it in other USB ports?
    Do other USB devices work since you changed the PSU?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      yes I have tried most of the USB's and also tried it on another PC
      Other USB's woek OK (I have mouse and keyboard using USB).
      NIR
        Did it work ok on the other PC? Are you able to see the dongle in the Device Manager?
          I only see under the "Universal Serial Bus Controllers" the name: "WIBU-BOX/RU"
          On the other PC I tried calling it in the browser but I did not install the WIBU drivers - Should I ?
          EDIT: When I un-plug the dongle the "WIBU-BOX/RU" disappears and returns when I replug it so I guess the dongle is seen.
          NIR
            Ok, so when you run the V-Ray license server, does it show any warnings?
              I get this:
              "Can not start VRLService application due to another instance running"
              Nir
                Hm, that means that the dongle is recognized properly. When you try to go to the license server web page, what do you get?
                  Nothing
                  I get the "page cannot be displayed" message
                    It almost looks like some firewall issue...
                      I turned the Firewall off and still Vray will not get its license.
                      (Windows Firewall is always OFF and I turned the Kaspersky's Firewall off as well)
                      NIR
                        Ok; what is the error code returned by V-Ray when you try to render?
                          On the render setup dialog I don't see the VRAY specific screens.
                          when I press render I get:
                          "Could not obtain a license"
                          Nir
                            Ok, what is the number in brackets after the message?
                              EDIT:it is [0]
                              I will upload the log file
                              Nir
