As per the attached pic you can see incorrect ligth distribution of the VRaylight. I've also tried it with geometry and VRayLightMtl applied, and it results in the same problem.
I have modelled the "wall" and "ceiling" in 3 different ways, and each results in same error.
From the left:
1. Wall and Ceiling touches with the wall going up past the ceiling
2. Wall and Ceiling slightly cuts into each other
3. Wall and Ceiling COMPLETELY crosses and cuts through and past each other.
The Problem:
The light spills up the wall as it should. But then what is going on at the ceiling? The light from the wall is suppose to nicely "flow" and spill from the wall onto the ceiling. But it DOESN'T!!! It fades from the wall, then suddenly it is BRIGHT again on the ceiling? This is incorrect and gives the impressions that the wall stops short below the ceiling in all 3 cases, and another light spills from BEHIND the wall onto the ceiling, which is obviously NOT the case.
So all you smart people out there, what is going on here?
From the left:
The Problem:
