Hello,
I am having some strange issues in a scene in which a car is driving through a tunnel.
1. The car's headlights were not rendered until I deleted some objects which were far behind the lights (these objects should not have influenced the headlights at all).
I did some tests to figure out what might cause this problem. When I turned off all lights in the scene (also the headlights) and switched to standard material override, the whole scene was rendered in bright colors (although "Render hidden lights" and "Render Default Lights" were turned of).
I then found out, that I had applied a VRayLight-Material to the Infotainment Display in the car's interiour a few days ago. The VRay Light-Mat had "Direct Illumination" switched on. When I deactivated Direct Illumination everything was fine again.
2. I have linked a VRay phys. camera to this car. I activated motion blur to get a blurry background. But as long as motion blur is activated, the headlights are not visible anymore. If deactivated, the lights are fine.
Of course I double checked that these headlights are linked to the car as well. Any idea about this?
