HowTo: textured projector light with env fog
  • HowTo: textured projector light with env fog
    Hi all!
    I've been trying to utilise vrayenvfog in producing something like this:
    http://www.todaygadgets.com/wp-conte...VPL-VW90ES.jpg
    Basically what I need is a vrayenvfog projector light, which in my scene is used to simulate a light coming from a cinema projector. Right now the spotlight interacts with the fog, but no matter what I do i just can't force it to use the bitmap in the light cone. Using it in the ligh't 'projector map' slot does nothing, and the same bitmap in the fog's 'fog color' slot renders it completely black.
    Has any of you tried something like this? Any luck?
    Perhaps I'm doing something wrong, but have no idea what...
    the purpose of a ninja is to flip out and kill people.
    the purpose of an architect is to flip out and design for people.
    ________________________
    www.1050.pl / www.kinetik.pl
    if your using a max spotlight change the shadows to shadow map and it should work
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      You can put a transparent plane in front of the light, much like a real projector...
        Ok guys, thank you very much for the suggestions...
        ...it seems that I did somoething wrong, because the light works just fine WITHOUT the need for shadow maps.
        standard target spotlight + texture in a 'projector map' slot + vrayenvfog = just what I needed, but somehow wasn't able to achieve
