I haven't use afterburn in a while and now I can't make afterburn work with vray anymore (since then I updated fumeFX to the last version). I must admit that in production I got so many troubles with vray and afterburn that I always end up using scanline to render Afterburn elements, but now I have some free time I would really like to find a way to render Afterburn in vray without bugs and crashes.
I use Afterburn 4.0b and I am trying a test scene with just some pflow on a sphere with afterburn and I try to render with vray. With afterburn alone it works. But if I add a plane in the scene with a vray material it will work at first but if I render many times, it will end up rendering entire black frame and then I have to switch to scanline and switch back to vray to be able to render again correctly.
This is using ABshadow map.
If I try with vrayshadow, max just crash with an esoteric error message...
render correctly at first with ABshadowmap
without changing anything, starts rendering black... and don't stop doing that unles I switch to scanline and back to vray.
crash with vrayshadow
