VrayBlendMtl bug
  • VrayBlendMtl bug
    I have a multi-sub material. If I click on one of materials, and make it a vrayblendmtl, and use "keep old material as sub-material" I loose "go to parent" icon to go to other multi-sub materials. I can retrieve it if the material is already in the scene and I pick it up with an eyedropper tool.
    www.hrvojedesign.com
    Can you tell me which 3ds Max version are you using? I remember there was a similar issue, which was fixed in newer 3ds Max versions.
      i'm not sure about newer versions, but this issue exists in max2009..
        Yes, I had this same issue. It doesnt happen now in 3dsmax 2010 or 2011.
        Regards
        Steve
        My Portfolio
          still happens in 2010 for me.. 2011 is fixed, though. to reproduce:
          1. create a multi\sub object material in the material editor
          2. drill down to any sub-material
          3. click the material button to the right of the material name (this is a "Standard" material by default)
          4. select a VrayBlendMtl from the material\map browser
          5. choose "Keep old material as sub-material"
          result: entire material tree is overwritten with the new vrayblendMtl and "Go To Parent" is grayed out
          doing this with a standard blend material works correctly and you can still go up the material tree to the original multi-sub material.
          i assume this is a max bug since it's fixed in 2011, but to confirm: is this a max-only issue or does it involve vray?
            Have you applied all the max updates...not sure if they would fix. I'll try and re-create the error now.
            Regards
            Steve
            My Portfolio
              Ah, yes, you are right....
              Regards
              Steve
              My Portfolio
                Yes, I use 2009 too.
