VRay2 - Environment Fog crash
  • VRay2 - Environment Fog crash
    I have a scene with a few geometry vol fog gizmos which renders fine.
    When I click merge in the Environment tab and select the same scene to duplicate my EnvFog effect it seems to merge fine - although no gizmos is now attached to that effect. When I select the merged effect and click Add under the Gizmo tab max crashes.
    Edit:
    It seems a bit random now when I remove and add gizmos which ones will be active when rendered.
    Scene:
    dense_nebula_02.zip
    http://henrikbclausen.com
    Vray EnvFog really crashes.
    1) I made a simple scene. I think falloff radius didnt work (only new falloff per gizmo)
    2) In this scene, make one environmental fog in one gizmo, then make another envfog and apply another object as a gizmo. But when I switch to the first envfog, it has the second object as a gizmo. I think its a bug, becose its render ok in both gizmos, but in the menu objects is wrong in the list and when I wanna change these objects, remove or add, vray crash.
    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
    2D | 3D | web | video
    jiri.matys@gmail.com
    https://gumroad.com/jirimatys
    https://www.artstation.com/jiri_matys
    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
    https://www.instagram.com/jiri.matys_cgi/
    https://www.behance.net/Jiri_Matys
    https://cz.linkedin.com/in/jiří-matys-195a41a0
      Anyone else experiencing these problems - or are they already fixed for the next beta?
        Thanks for reporting the issues; will check these out.
          Meanwhile I may have another issue.
          This scene has a vray light and GI enabled IR+LC:
          First image with fog emission value 1,1,1.
          Second image with fog emission value 0,0,0 (I only updated the region).
          Is it really supposed to spike off that much of a difference?
