Vray Resets when being accessed by Maxscript
  • Vray Resets when being accessed by Maxscript
    I am working on a small script to automate Flythrough Animations for Vray.
    Unfortunately Vray Settings sometimes tend to rest to default when testing the script, but I could not find the bug. Furtheron I could not retrace the Error, since it sometimes works fine.
    Can anybody tell me at what point Vray tends to react in this manner (Reset to defaults)?
    Best regards, Peter
    P.S. Find an excerpt of the code we used below:
    TransferRender = renderers.current
    TransferRender.options_dontRenderImage = true
    TransferRender.gi_on = true
    TransferRender.gi_primary_type = 0 -- Set to IR
    TransferRender.gi_secondary_type = 3 -- Set to LC
    TransferRender.gi_irradmap_preset =0 -- custom mode
    TransferRender.gi_irradmap_showCalcPhase = true
    TransferRender.adv_irradmap_mode = 1 -- IR Multiframe Incremental
    TransferRender.gi_irradmap_minRate = -4
    TransferRender.gi_irradmap_maxRate = -2
    TransferRender.adv_irradmap_autoSave = true
    TransferRender.adv_irradmap_autoSaveFileName = PathIrradianceMap.text
    TransferRender.lightcache_showCalcPhase = true
    TransferRender.lightcache_subdivs = 1000
    TransferRender.lightcache_mode = 1 -- LC Flythrough
    TransferRender.lightcache_autoSave = true
    TransferRender.lightcache_autoSaveFileName = PathLightCache.text
    Will try to reproduce this here; can you tell me which 3ds Max version you are using?
      Hi, Vlado
      I set this script up on my laptop with VrayDemo installed. Tested the script in our office with the full Vray-Version and the error did not occur so far.
      Max is 2011 Design.
      Thanx so far ... Peter
        It is normal for the demo version to reset it's settings.
        Also you may have it fixed already, but in the code excerpt above there is a problem with the following line:
        "TransferRender.lightcache_showCalcPhase = true"
        the lightcache_showCalcPhase is Integer value and assigning "true" returns conversion error
        Best regards
        Alexander Kazandzhiev
        V-Ray for 3ds Max developer
