I have a strange problem while backburning a job.
Everytime I backburn a job with VRay, render goes well, VRay saves the image via VFB, then backburner flags the job as failed with the Error message "could not read/write file type C:\Program Files\Autodesk\3ds Max Design 2010\renderoutput\"
It's annoying because it restart the render instead of beginning the next, while the image was properly saved by the VFB... A workaround was to prevent the Manager to retry the job but another node might kick in the render cuz Manager thinks it failed.
You'll tell me it's a network path problem, but 3dsmax render output is unchecked, VFB output is a correct UNC path, elements paths are blank (Anyway, I think VRay ignores the elements path if the render output is unchecked?) and every other path I might think of is always UNC and valid
Also, no 3dsmax user path is C:\Program Files\Autodesk\3ds Max Design 2010\renderoutput\
Can't see what could cause this problem, although the solution must obviously be very simple !
I'm with Vray 1.5.SP5 and Max 2010
