RenderID different colours over network
  • RenderID different colours over network
    Hi
    Been using VrayRenderID over distrubuted rendering (2 computers) with no problems.
    Suddenly the buckets from the 2 computers are rendering different colours for the same object.
    So RenderID is a mess and useless.
    Anybody know what could have caused this problem and how to solve it.
    Cheers
    Derek
    Is there a particular moment when this started happening (e.g. hiding or unhiding objects, changing something in the scene)?
      I honestly cant remember. Only once I had rendered and fliped to the renderID saw it was a mess.
      So there is no specific thing I could point to that might have caused it.
      And it now happens on the other scenes that I open as well.
      I am using Itoo Forest software with lots of proxies, if that helps
      Help!!!!!!!
        Restarting 3ds Max (on the slaves too) and using the "restart slaves on render end" option in the DR settings will probably help.
          "It is set to restart slaves on render end" and have restarted Max with no change.
          When I have finished with current project will see if I can solve problem and will post again for help.
          Will just have to life with it for now, almost finished everything for year, so not a big problem
          Will probably upgrade to 2.0 in the NY anyway.
          Thanks for help.
          Cheers
            Ok then; if you keep having the issue, would it be possible to send me a scene to vlado@chaosgroup.com ?
